climate control issues
I am new to this forum, glad to find it.
This is driving me nuts.
When driving over 40mph, even when "0" is selected I get warm air coming out of my vents.
The air works whenever it wants to? and when it does I also get hot air on the window and those small vents by the doors and foot vents-at the same time?.
I get cold air in the middle vents across all 4.
I have been reading posts and I do not know what to start with?
monovalve?
fuse?
Climate control unit replacement?-$$
Thanks in advance
If the heat operates concurrently, the climate control unit might be bad. You can get rebuilt units online at www.thepartsbin.com.
If the climate control unit does not fix the problem then I need to do the vacuum element.
Is there a was to diagnose which one is the problem?
1) When set to the minimum temperature, cool but not cold air blows? What could be the cause? Needs charging? More coolant? Could the coolant be leaking? Any help would be appreciated.
2) When set to heating, air comes out of the vents by the doors as well as from the vent in the rear seat area, but very little heat comes out of the big vents in the middle. These vents blow out air well when set to cool but not when set to heat. Any idea of what's going on here? Even the local mechanic told me he has to look at the car before he can answer my question.
Thanks for all the help.
braverichard: If the air is not frigid (it should be ice cold), the refrigeration system is low on freon, the compressor has failed, or the Klima control unit (protection) is faulty.
Warm air does not blow from the center vents. This is to divert as much air as possible to the windshield for purposes of defogging. Safety first!
Disconnect the battery before you remove the pushbutton unit.
