S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
300SDL Cranks but will not start
Old 08-27-2017, 07:00 PM
richnronda's Avatar
1986 300SDL , 1987 300TD
Just finished doing some major work : valve job, new chains , glow plugs ,etc. During the process I replaced the O-Rings and Copper seal washers on the 6 outlets on the injection pump. Unfortunately the tip of my washer removal tool had gotten magnetized and disturbed 1 of the plungers under the spring. I have read that this is the death of the pump an engine will not start. I felt pretty good about re-inserting it , but engine will not start ?? Can anyone confirm or deny this fear ? I have cranked a long time and have fuel leaking at all 6 ( loosened ) injector pipes. I do not however have fuel spraying as if under pressure ? Finally although I bought a special tool that screws into the side of the pump plug...I am not 100% confident the pump is timed properly ?? Appreciate any thoughts or experiences. If it gets to that point...does anyone recommend a pump rebuilder ? Thanks Rich
Old 08-28-2017, 04:19 PM
Plutoe's Avatar
Received 1,019 Likes on 947 Posts
1999 E300TD
Post your VIN!
Old 08-28-2017, 05:30 PM
richnronda's Avatar
WDBCB5D9GA274900
Old 08-28-2017, 07:23 PM
Plutoe's Avatar
1999 E300TD
Do over--invalid VIN
Old 01-15-2018, 04:06 PM
sliver 126's Avatar
1984 300SD
Are your glow plugs functioning? Sometimes the Glow Plug Relay will develop a hairline crack in the fuse and you won't start.
Test by jumping the fuse poles with a piece of 14G copper housewire.
If it starts replace the GPR fuse. If not on to next down the line.
Quick Reply: 300SDL Cranks but will not start
