S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
Om617 operating temperature question
Old Mar 4, 2019 | 06:41 PM
Kevin Blanchard's Avatar
1983 300SD
Hello fellow Benz lovers I have recently purchased my first Mercedes it's a 1983 300 SD with 141000 miles meticulously maintained by the previous owner who ordered the car and drove around Europe on vacation then had it shipped back to the states. The only thing wrong with the car is that the stereo won't turn on (fuse ok under hood). Mainly I am curious about what the normal operating temperature of the om617 should be. It has gotten as high as 100c and fluctuates quite a bit by that I mean erratically on the guage. I'm thinking it's the temp sensor. What do you think?
Thanks for any replies
Old Mar 4, 2019 | 08:32 PM
chassis's Avatar
2017 GLE350 4MATIC
Welcome! Please post a pic of your M-B. Around 200 deg F, according to this: http://www.peachparts.com/shopforum/...emp-om617.html
If the temperature gage is fluctuating, I would first check to see the coolant is filled to the proper level. Next is to look for coolant leaks. Then try to detect if coolant is being consumed by the engine. The gage may indeed be faulty. The coolant level and consumption checks will help diagnose the situation before targeting the gage/sensor.
Old Mar 5, 2019 | 12:32 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W126 forum...
