S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
New with old problems
Old Apr 20, 2019 | 11:23 PM
Mason560SEC's Avatar
1989 560 SEC
Recently aquired a 1989 560 sec with 32k miles the car needed aome tlc so i replaced the fuel filter both pumps acumulator new injector seals and fpr blew out the lines changed the uper intake with distributor intake idle valve ezl computer coil plugs wires cap rotor battery "cold start sprayer" wrong wording but any way i did all that still no change when the car starts it will idle originally with lota of smoke and exhaste was plugged so i have replaced the headers and at the moment its open headers but when you give it any gas it will die or bog down dont know where to look thought i had it whipped before even starting it know i dont know wich direction to head so many any advice with similar cases would be appreciated
Old Apr 21, 2019 | 09:58 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W126 forum...
