Replace instrument cluster lights with LED's (How to)
300 SD,92 VW CONVERTIBLE,78 SUPER BUG CONVERTIBLE
390 ohms not 390 k ohms
can't use a 390 k ohm you have to use a 390 ohm resistor ,basically anything between 250 ohm and 500 ohm,the lower your resistor the brighter you lights will be.
