S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
Engine starts then dies
Old Mar 26, 2021 | 09:16 AM
Butch Garcia's Avatar
1987 300 SE w126
Hi ! I own a 1987 300SE W126. 2 weeks ago i replaced the car battery but i did not run the car. Now that i want to use it, the engine starts for about 5 seconds and then dies. tried to start it more than a dozen times but it would die right after it has started. Am totally new to this Forum and I would appreciate and value whatever professional advise, comments, suggestions as to the reason why this happens and what i can do to make the engine run. Thanks.
Old Apr 12, 2021 | 09:39 PM
ozkanuk@hotmail's Avatar
1990 w126 300SE (EU) & 1989 560SEL (US Spec)
did you mean this happens when the engine is cold? (or hot, too?).... this could be for many reasons...cold start injector & its process, leaky injector (you have 6 of them), low fuel pressure meaning you lose pressure overnight (or 30+ minutes after you shut down the engine, etc etc.
There could be a bad fuel pump, fuel filter, fuel accumulator, I hope not, but internally leaking fuel distributor, EHA going bad (do you smell fuel while driving?)
Before you take it to a mechanic, try forcing fuel pump to do 2-3 may be 4 cycles to send fuel to the engine in the morning. Turn on the ignition (do not run the engine) and listen for fuel pump `s little buzzing for 1-2 seconds, then turn ignition back to 0 and do this again for 2-3 times then run the car.
You need to understand the system before people start changing parts. Sometimes you have to, but "which one" needs a good mechanic.
I`d suggest you watch/subscribe/make little donations these channel and videos. All kinds of engine problems are covered. Don't be like me, be patient, watch and take notes. It is complex but not a rocket science. If I can understand, you can, too.
Then you will have an idea and maybe work with your mechanic.
https://www.youtube.com/user/schilleryu/videos (he is very kind and fast to respond)
https://www.youtube.com/user/Mercedessource/videos
https://www.youtube.com/c/MercedesCl...eHedary/videos
Good Luck.
