Idle Control Module on a RHD W126?
I have ongoing idle problems and have mostly ruled out the ICV and vacuum hoses. Removing the glovebox (on the LHS) did not seem to show me the Idle Control Module, only some Air Conditioning bits and a box labelled TEMPERATURG**** Which I'm guessing is not it.
Is this guy going to be buried right behind the gauge cluster...? I'm not looking forwards to removing that. I'll probably try to see if I can get to it from below on the weekend.
Cheers
Sadly that's where the good new ends, it's held onto a bracket with a philips screw you largely can't reach (4cm gap above it), and a nut/bolt combo where you can get at the nut, but the bolt can't be seen and needs an ultra thin socket. I did what another guy on the net did and wrenched it out with a screwdriver. There's no good way to get it back in, if you were able to undo it normally, getting the screw back in or the nut back on would be extremely difficult at that angle, so it's probably going to have to be held in with gaffer tape.
Oh, the other guy I found who had this issue took the front seat out in order to get into the footwell, but if you put a milk crate outside the driver door, you can lie on that and the footwell on your back to get at this thing.
