S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
Transmission
Old Jun 18, 2022 | 03:02 PM
Scuba Saba's Avatar
2019 ZO6
Transmission
I just bought a 1991 560 SEC. Is it normal to have to let off on the gas slightly to cause an upshift?
Old Oct 15, 2022 | 08:21 PM
88 SEC's Avatar
No, you might want to check that the vacuum modulator is working correctly.
Old Apr 10, 2023 | 04:01 PM
Testcrash's Avatar
1985 300SD, 1990 300SE, 2002 E320 Wagon RWD.
Could also be the detent cable, it can be adjusted to change shift points and firmness.
