S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
unknown warning light and switch
Old Oct 12, 2004 | 02:39 AM
LRG's Avatar
LRG
1989 300SE
ok mind my ignorance, but I did not get a manual with the car. 300se. the warning light is the one next to the emergency brake light, it is amber/yellow, it is a circle with some dashed lines on opposite sides (I'm thinking brakes but just want to know for sure). and while i'm on the dash, what is the purpose of the exh temp light - just to let you know when it's hot?
the other query is the switch/dial located between the electric window switches - the odd symbol with a roller function??
thanx
Old Oct 12, 2004 | 11:46 PM
Jer's Avatar
Jer
1994 E320
The yellow light is for front brake pad wear. When the pads wear down, this light comes on to let you know it's time for new pads.
The dial next to the window switches is probably the front/rear fader for the speakers.
Old Oct 13, 2004 | 03:45 AM
LRG's Avatar
LRG
1989 300SE
thanx for the reply.
pads have plenty, maybe my rotors are getting down?! only seems to happen in conjunction with the emergency brake?
ummm on the dial, the head unit has controls for the fade and balance so......not sure
Old Oct 13, 2004 | 06:09 AM
trust's Avatar
a bit OT but it's been bugging me.
How's the manual for the car? Is it worth it?
Old Oct 14, 2004 | 12:49 AM
LRG's Avatar
LRG
1989 300SE
huh?
