S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
minor issues with conversion
Old Oct 26, 2004 | 06:11 AM
artimusprime's Avatar
Smile minor issues with conversion
back in July I started an engine swap (83 300sd engine, 86 420sel body) which has gone well save a couple of "minor" issues... one, the tach is inop -not sure which gauges to use... two, this was an issue prior to the swap, the driver door light switch is inop... three, the third brake light is inop... also, if anyone has any suggestions as to where/how to connect the glow plug system send them this way please.... yes, it does run will post pics soon
