S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
Part info Help
Old Oct 29, 2004 | 02:00 PM
500MPL's Avatar
'84 500SEL euro, '89 560SEL, '80 450SL
Part info Help
Replaced the plenum boot on my 84 500SEL and replaced a part called the fuel injection control valve, MB# 003-997-00-36. The part is attached to the throttle body and is activated by the throttle linkage which activates a small plunger. There are three vaccum ports on the valve.
Can any body tell me the correct vaccum routing and what systems do the operate.
Many thanks,
Old Nov 3, 2004 | 09:31 AM
rustys380sl's Avatar
that part affects your transmission
Old Nov 7, 2004 | 01:53 AM
500MPL's Avatar
Rustys380SL, can you be more specific. And do you have vacuum diagram that would clarify? Doesn't the canister in the fender, I don't know what its called, is somehow connected to this system. Any help will be appreciated.
