Car door locks don't work
1999 C230 kompressor
I own a 420 SEL and am seeking a way to troubleshoot the vacuum door lock system. The pump is good so it is either a vacuum line or one of the elements in the doors. HELP!!!!!
ablanco
ablanco
I had to replace my vacuum door servos (left rear and right rear) on my 1985 380SE--in May of 2002 with 102,084 miles on the car. My mechanic took care of it. As I recall, it was a pretty simple repair with no down time. Good luck, and welcome to the board!
96 S600 Euro, 91 560 SEC, 88 300TE, 87 560SEL, 86 560SL, 80 280SE, 64 Austin Healey 3000MIII
get yourself a vacuum tester from Advance or where ever.. Pull the door panel and plug it into the line feeding your door lock. If it works, you have a leak in the line somewhere, if not.. you need a new element.. Not a terrible job.
Jonathan
Jonathan
Map Light
Thanks for the advice on the door locks guys. My car also has a peculiar electrical anomaly. The interior light (the one above the rear view mirror) comes on when I'm driving and turn my radio on. If I leave the radio on it won't go out. If I turn the radio off it switches on and off with delay as it should. Any advice would be great.
Albert
Albert
