Oil Change Question From A Newbie
1990 560 SEL, 2004 Chrysler Pacifica, 1982 VW Camper, 1979 Volvo Bertone, Vespas
I recently took possession of 1990 560 SEL. I've been doing some research to get ready for my first oil change. All of the info I've found shows the use of a "Topsider". Is there not just an old fashioned drain plug in the pan that I can use? Considering the fact that this car doesn't have a glovebox, a missing oil drain plug wouldn't surprise me!
By the way: I LOVE THIS CAR!!!!
I wish I would have bought one years ago!
Thanks,
Erich
Thanks,
Erich
S600 Coupe. 560SEC, E55
Usual drainplug in bottom of oil pan. Be sure to disconnect the coil wire and turn engine over until oil pressure comes up after change to avoid timing chain damage.
1989 560SEL, 1999 S600, 2005 S600, 2008 S550 4Matic
Thanks,
Erich
Thanks,
Erich
The lack of a glove box is due to the fact that your car is equipped with a passenger side airbag. Sure, today all cars are equipped with passenger side airbags but also have glove boxes, however your car was the first car in the world to be equipped with a passenger side airbag. Those were the first years, so at that time M-B was still learning how to properly position the airbag while preserving the space for the glovebox.
You have a truly wonderful car. Take care of it and it will take care of you. Gotta love all that torque!! :v
