S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
US vs. Euro Technical Differences?
Old Jan 13, 2005 | 12:44 AM
CynCarvin32's Avatar
Mercedes Benz
[QUOTE=drakon]over it, so it doesn't matter that they are different shapes.
QUOTE]
Ok let me get this for a second....im really miffed here.
You think the guy put a newer cam cover on his car to go OVER the old cam cover? Was this done in an effort to keep the car warm on those long cold lonely nights? That would be just great... make the motor run even hotter!
I vote for the M117 with the M119 heads....
Ever try to find a 4 valve M117 head to put on after you fry the weak heads on the hammer motor? Well... there are none really so if you want to keep the 4 cam motor you need to go to the best thing.. a modified M119 head.
Old Jan 23, 2005 | 07:33 AM
drakon's Avatar
1990 560 SEC (modified), SLK55, CLK500
This issue was discussed way back, over on mbcoupes.com.
http://db.mercedes.cx/sec/200201/08/0007.html
once again, it is possible that the car has the 119 heads fitted to 117 block, but highly unlikely. However if it is possible, i would love to do it.
