w126 380 sel fuel issue
Subscribe
May 8, 2025 | 09:13 AM
so ive got a 380sel 82' and ive got power coming from the relay at 87 but nothing at the pump. if i just a wire from 87 to the pump it will kick on so i have an issue between relay and pump. wiring diagram shows an inline connector i cannot find and i can see the wires go from truck to behind rear seat (passanger side) mfrom there no idea where it goes need location of the inline connector or just the wire routing from the relay to the pump.
Reply 1
May 10, 2025 | 06:31 PM
moved to W126 forum...
Reply 0
May 11, 2025 | 11:36 PM
Quote: so ive got a 380sel 82' and ive got power coming from the relay at 87 but nothing at the pump. if i just a wire from 87 to the pump it will kick on so i have an issue between relay and pump. wiring diagram shows an inline connector i cannot find and i can see the wires go from truck to behind rear seat (passanger side) mfrom there no idea where it goes need location of the inline connector or just the wire routing from the relay to the pump.
Also check wires at pump end for a likely internal break in a wire, it occasionally
occur due to flexing at this end.
Adler
Reply 0
May 24, 2025 | 04:11 PM
OP how is the relay triggered?
We used to get to replace a ‘main fuel relay’ or some such with regularity.
Reply 0
Subscribe
Currently Active Users (1)
