S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
m103 intermittent issue
Old Jun 28, 2025 | 01:38 AM
Spaceman80's Avatar
1990 300se
I have an intermittent problem: The car (1990 300se, Canadian Spec) )dies if I blip the throttle too quickly. If I increase it slowly, it shakes/vibrates.
Maybe unrelated but the car starts well when cold (or in cold weather) , when hot, I need to help it by depressing the gas pedal to start.
Last weekend the problem happened at a stop sign and the car refused to start up until i let it rest for a good 30 minutes. Did anyone encounter this and if not, where would you start looking?
Old Jun 28, 2025 | 03:28 AM
adler's Avatar
300sel- w109 .1971
103 engine
For starters replace the fuel accumulator and filter . If it restarts when engine has cooled is a sign of failed fuel accumulator. Low fuel pressure gives varied fault symptoms.,hence 'for starter'
Old Jun 28, 2025 | 10:53 AM
Spaceman80's Avatar
1990 300se
Ok, the fuel filter is new so I will order an accumulator. This reminds me of my 1986 bmw 728i e23, BMW made a small hose/kit with a checkvalve to address hot starting issues. However I am not too optimistic because while the hot start issue is always there, the misfire and stall is occasional and intermittent.
Edit: I will order a fuel pressure regulator and I think there is a "damper"? too? while I am at it.
Old Jun 28, 2025 | 08:25 PM
adler's Avatar
300sel- w109 .1971
as the fuel pressure decreases and due to vapour lock, issues like misfires, a occasional bang in manifold may manifest itself leading one to think there are additional issues. Step by step will resolve all issues fueling being first
Been through all that with my 300se , a Euro model .
Old Jun 28, 2025 | 08:35 PM
Spaceman80's Avatar
1990 300se
OK understood, this makes sense. I will start with fuel system diagnosis and overhaul. Will update as progress is made. Thank You Adler.
Old Jul 23, 2025 | 08:43 PM
Spaceman80's Avatar
1990 300se
Status update
Today the car started well from cold as usual , i hooked up a multimeter and took a look at the duty cycle values from the x11 connector. Red on pin3 and black on pin2. With ignition on but no running engine i get 69.9% which confirms my ecu is capable of giving diagnostic codes through duty cycle values. At full operating temp, the percentage hovers around 20% and varies which I think indicates normal operation at idle. The car ran fine without misfiring today. Still has a hard time restarting when hot. I am waiting for delivery on the fuel accumulator and will be running some more tests.
In general, how likely are the valve stem seals to be bad on the m103 engine? I put a paper in front of the exhaust pipe and it "flutters" as if there is sucking action in there sonwhere instead of only blowing exhaust out.
Old Jul 25, 2025 | 12:55 AM
adler's Avatar
300sel- w109 .1971
103 issues
103 engines do have an issue with valve stem seals leaking as they age . Effects the spark plugs with oil deposits .
A leaky fuel accumulator always require long cranks to fill in the fuel.and start the engine till the time accumulator is replaced. Expect all kinds of starting issues.
Old Aug 14, 2025 | 01:34 PM
Raymond Jonkers's Avatar
W126 300SE euro
Fuel pressure is key. Fuel accumulator was replaced on my 300SE, solved all hot start issues.
