S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
300SDL Check Valve and Brake Booster Line
Old Mar 22, 2026 | 12:36 PM
madmax03's Avatar
2003 E320
Hi all. I have been having problems with the vacuum system in my 300SDL and so I tried to test my vacuum pump. I pulling the vacuum line off of the t-shaped check valve that goes into the brake booster vacuum line and ended up breaking it as it is very brittle. I cannot find the check valve anywhere and it seems like it is almost impossible to get out of the vacuum line anyway without at least using a heat gun. I tried looking for the complete vacuum line along with the check valve so I could replace the entire thing but I cannot find one anywhere. I have also looked at making my own but I am at a loss as I cannot find the check valve anywhere. Could someone please point me in the right direction in regards to what parts I could order, preferably with links to the parts? I have included pictures so I hope that helps. Thank you.
