anyone change a water pump on 420SEL?
89 420 SEL and 97 E320
How do you get to the bottom bolt on the water pump without removing the $*%^(#*% fanbelt pulley?
Well, it's done
Ended up having to remove the bolt on the dampener and pulled it out about 3 inches to have access to that bottom bolt - this was after pulling the alternator so that I had room to put my hand in there!
Amazingly enough, the reinstall went VERY smoothly - it took me about 3 hours to disassemble and remove the old pump, and about 1.5 to put it all back together again. Go figure.
