Accumulator change on 560
1991 560SEL
Somewhere I saw a step by step on changing out the accumulators on a 560 (or similar systme) and canot find it now. Anyone recall where that was posted??
1983 380se and 1981 280 ce
Try this link.....http://www.benzworld.org/forums/foru...hock+absorbers
I have just done mine and it was simple enough...Do'nt forget the special oil (hydraulic fluid) from MB and (some) others.
This also may be of some assistance especially if you have access to the workshop CD's
http://www.300sel.com/HydroSuspGuide.pdf
1991 560SEL
Thanks guys, new accumulators on the way. The ride in my car will about bounce you to the ceiling in the rear! I have moved the lever on the valve and it will go up and down.
2002 E55 - Tectite
Accumulator replacement
I just replaced the accumulators on my 1989 560SEC this afternoon.
I also "flushed" the hydraulic fluid.
First I opened the bleeder on the leveling switch. This allow the pressure to bleed off. I used a piece of clear plastic hose on the bleeder to direct the fluid to my oil changing pan.
I disconnected the return tube from the front hydraulic fluid reservoir and used another clear plactic tude to route this fluid to another container.
Then I started the car and watched as the fuild drained out of the reservoir. I added new fluid until I saw clear fluid draining out the back and from the return tube. This step isn't necessary, if you don't want to flush the fluid.
At the aacumulators there are two lines. Disconnect both and remove the three nuts holding the accumulator in place.
Take the accumulator to a bench vise, and remove the fitting in the end of the accumulator. Put this fitting in the new accumulator, and now you're ready for re installation.
Put the new accumulator in place and just start the three nuts. This allows the accumulator to move a little and this will assist in starting the small fitting that's on the hard line. Once its started, tighten the three nuts, install the larger fitting and tighten both fittings.
That completes one side, and the second side will go quicker, cause of your recent experience. Took me about 4 hours start to finish. I used about two liters of fluid. Good Luck.
2 many to drive in 1 day
Parts
What did the 2 parts cost , I know I may do it , but it will be a long time before they go bad , still need to know the bad news in the cost . Thanks, DW
1 Post
1991 560SEC Teal 1989 420SEL Ice Blue 1984 500SEC White
Besides the accumulators , there is also a larger rubber shock mount that replaces the ones currently on the shock/hydraulic rams. It took that clunk sound that you can get when you go over a speed bump from my car. This was on the SEC 126's that this worked.
Bruce
Benzitch
Bruce
Benzitch
