Right Rear Window inoperable - Help
A couple of days ago, we were on our way back from dinner with some friends. A friend in the back seat pushed the auto power up switch on the rear door, and the window went all the way to the top. Just as it got to the top, there was a loud pop noise that came from inside the door panel.
I tried to lower the window with the front seat master switch, and it lowered down about 1/4 of the way down, which was all that I held the switch for. When I tried to power it back up, nothing. It just stopped where it was and wouldn't move. You could hear the motor, but there was no movement.
Parked the car in the garage for a few days (not the daily driver). I removed the door panel to investigate, and at the bottom of the inside of the door were three pieces of white plastic. Put together, they formed almost all of a circular plastic piece that was white in color and approx 3" in diameter. Another piece was still missing, it wasn't at the bottom of the inside of the door. At this point, after some more testing of the motor, the window is now all the way down and will not come up at all.
So after all that description, my question is this. Does anyone know what this white circular piece of plastic is? Can I purchase this piece seperately? Do I need to purchase a new regulator or new motor (or both)? THe motor still works (or so it seems, I can hear it running).. it just won't raise the window.
Thanks for any help you can provide.
i had my mechanic friend that specialises in audi and VW fix it.
he used some other car parts to replace that plastic piece, i guess it's a common problem on this car, and some parts are interchangable.
look for a used part if you can, new assembly from the dealer is to much $$$$$
