S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
??? Mass Air flow
Old Sep 16, 2005 | 09:36 AM
Rod Spohn's Avatar
2011 E350 Bluetec, 1996 S320 & 2006 E320 CDI Sold to my son & 2017 GMC 2500 Diesel Pick up
??? Mass Air flow
I have a check eng light that came on. I had the Shop I go to check the codes and they said its the Mass Air Flow sencer. They cleared it & I went about 3 weeks before it came on again. Had it cleared , same about 2-3 weeks. so if it is the MAF it work and the fails.. Can the MAF be cleaned or repaired etc? Anyone, anyone.....
OH its on a '96 S320
Old Sep 16, 2005 | 10:53 AM
brett san diego's Avatar
1997 S600 Sedan
I have followed experiences of people who have cleaned MAF's a couple of times with success, then eventually, cleaning no longer works. They simply go bad with time and use and will require replacement. Try a no residue electrical contact cleaner spray.
Brett
Old Sep 16, 2005 | 01:06 PM
pcmaher's Avatar
1995 S600 Sedan
Could be the insulation on the wiring going bad and causing shorts. Read this...
http://v12uberalles.com/AMM_rewire.htm
My slight surging problem (and the occasional Check Engine Light) went away after this and the ETA rewire.
Old Sep 16, 2005 | 03:03 PM
Rod Spohn's Avatar
Gentelmen, Thank you. At the cost of a new MAF - I think I'll try the Elect. cleaner first.
Old Sep 27, 2005 | 09:19 AM
Rod Spohn's Avatar
Fyi
Cleaning the Mass air unit with Elect cleaner seems to have worked so far. If that was my problem the check eng light has not come back on. Once again thank you.
Old Sep 27, 2005 | 01:14 PM
Bernanke's Avatar
91% isoprypyl alcohol in zip lock baggie works best in my opinion
