1992 400se
bought a 92 400se, great car, i go and take my car to get a tune up, generally speaking like cap,rotor, plugs, wires, blah blah.....car was running smoothly until i get the car back from the mechanic, i ask him, "hey man whats with the with the shake?" he tells me "the number 4 cylinder piston has low compression 60lbs" but the car was not like that before ya know...ok so i take it
and what i did was i took it to another shop, benz shop, they told me it cant be the piston so they check it out....so it needs a new wiring harnesss, i was told its common for these to have this, ok but what about the shake it had when i brought it? they told that when they change the wiring harness that they would be able to get a diagnostic
so now, i spent 999$ on the tune up alone, another 1K to change teh wiring harness...and god knows what else...less than two weeks and im having a bad experience with this car...miles on the car 132xxx
$999 for a tune up seems a little high, but I'm not sure what was included in that price - plugs, rotors, rotor caps, fuel filter, ????
During the time of my owership of the 400se, I've replaced many items, so feel fee to ask if you have any questions or need information.
Russell
A couple thousand dollars of repairs on a 14 year old car that cost around $50,000 in 1992 is to be expected. Prepare for more. This forum and a couple other forums (www.mbnz.org, www.mercedesshop.com) will be very helpful
Brett
well, one of you is right i did not do my homework before buying the car, i did know the parts are always expensive i knew that. i was just concerned. the car is fixed now, on top of replacing the wiring harness, they also found out that the cruise control was not working, so they fixed that as well. they also told me that the previous mechanic who worked on it, its not at fault or responsible for the wiring harness, it was in pretty bad shape.
