S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Spark plug Question
Old May 20, 2006 | 12:02 AM
Rod Spohn's Avatar
2011 E350 Bluetec, 1996 S320 & 2006 E320 CDI Sold to my son & 2017 GMC 2500 Diesel Pick up
Spark plug Question
Its time for a tune up and I was thinking of trying the 4 electrode plugs I've seen in Proformance products catalog. Are these really any better than standard plugs? Any preferances you guys have? ( I have a 96 S320 ) Is it worth the cost for these plugs?
Drive on
Old May 20, 2006 | 01:31 AM
NZ_Benz's Avatar
1993 300SEL/S320
Drive on
I have seen people use the platnium plugs and they last a bit longer. Put it this way with the size of the car and the engine etc, there will not be a hell of a lot of performance difference. The car was designed with the OEM plugs in mind so why not stick to it.
Old May 20, 2006 | 11:45 PM
brett san diego's Avatar
1997 S600 Sedan
Just go with factory recommended plugs. Too many bad experiences in the old Porsche 911 camp for me to think about using the Platinum +4 plugs in any car.
Brett
Old May 21, 2006 | 07:57 PM
Hattaresguy's Avatar
1987 300SDL aka the "Money Pit"
Drive on
Don't, your car won't run right. Stick with the Bosch plugs that MB specs. They cost a whole $2 each from the dealer and take all of 10 minutes to change. Change every 30k.
I think this:F 8 DC4 is the number you need.
Old May 22, 2006 | 02:15 PM
Rod Spohn's Avatar
OK went with the Bosch, also replased the fuel filter. The car runs great Except it sometimes is "a little" hard to start. I have to give it a little throttle to get it started and it kind of surges when it starts. Like revese up and then evens out. I thought the plugs and filter would do it since they are @ 41k miles. any Ideas.
Drive on
Old May 23, 2006 | 01:25 AM
1997 S600 Sedan
You shouldn't have to give any throttle to start an electronic fuel injection car. Sound like it's not getting enough fuel. Fuel pump, fuel pressure regulator, air mass meter, or maybe the engine computer (ECU)? These are wild guesses, by the way.
Brett
Old Jul 1, 2006 | 09:18 AM
nkpnkp's Avatar
I agree with OEM
I agree with oem parts from Boach copper core. Inexpensive works very well.
