S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Power assist failing
Old Jul 1, 2006 | 07:26 PM
qha000's Avatar
Hey guys,
When I bought my 92 600 SEL a couple of years ago the dirver's side power assist was not working and I learned for this forum that a lot of other people had the same problem. Now the other doors/trunk are failing one after the other. What exactly does this mean? Right now only the rear door works. Thanks.
Old Jul 2, 2006 | 09:28 AM
Peter Guenther's Avatar
92 500sel/01 320e wag
Pull the fuse in the trunk for closing assist for a few moments, that will reset the pump. The pump has safeties that have pressure and time parameters, most of the time it will work for a while. The system defeats the circuit if it can not sucessfully close a door on the third try. I am on my 3rd pump (replaced two) it appears they are 5 year items. The last time MB checked the hoses for leaks found none, and replaced the pump for free. There is a lot of info on "BenzWorld" search "closing assist" most of the time its a replace the pump $600 or so. The pump sends pressure to the doors to close, after it sees a signal from the lock, after the close confirmatio it sends vacuum to reset the diaphram. You will usually heasr a hiss in the drivers side of the trunk as it resets. The pump is located on top of the rear wheel passenger side way back take the lining out of the fender and the rear
http://www.benzworld.org/
http://www.beckmanntechnologies.com/. sell rebuilts, be careful about ebay you could get one no better than what you have
