S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
HELP! Will Rims from a 04 S430 4matic fit my 92 400SE?
Old Aug 20, 2006 | 12:00 PM
chesee48's Avatar
17X 8.5....
Anyone know for sure?
thanks guys...
Old Aug 20, 2006 | 02:01 PM
bhappy's Avatar
I think you will need the offset information too to make sure the wheels will fit or not.
Old Aug 21, 2006 | 02:29 PM
chesee48's Avatar
Et 46
Old Aug 22, 2006 | 12:34 AM
chesee48's Avatar
stamped on the wheel is: 7 1/2Jx17H2
ET 46
Si 7 wa
Old Sep 11, 2006 | 11:53 PM
markku's Avatar
S320L -97
W220/W140 wheels
W220 wheels should fit almost perfectly, there is only 5 mm ( 0.2" ) difference in offset. I have a set of W220 wheels with my winter tires. Complete table of Mercedes wheel/model/offset combinations is here http://www.mercedeswheels.net/
You should check the load ratings, 225/55R17 seems a little small for W140. W220 in not as heavy as W140.
