HELP !! Aspirator Location and replacment
I'm not able to post attachments. Aspirator vent is between the front map lights.
Check in - car temperature sensor aspirator blower by placing a small piece of paper (approx. 1/2" sq. ) over aspirator blower vent grille with ignition "ON" . If there is sufficient ventilation the paper will remain on the vent grille, if not check aspirator blower for voltage supply and function. The after - run time for the blower motor is approx. 1 minute.
