S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
And its STILL cutting out
Old Oct 29, 2006 | 01:22 PM
ajbristol's Avatar
300SEL (S320)
ok folks, heres one for ya.. 92 - S320 I have changed crank sensor, fuel pump, fuel filter, plugs, checked fuel relay, plug leads, injectors, etc etc. Having had this car for several months now I'm losing it with Mercedes vehicles, Car starts drives for around a mile or so and coughs and splutters like you've ran out of fuel, engine dies, go to restart it and it'll turn over until the cows come home but will it start.... NO, good spark, injectors electrically ok, Leave it for approx 30 - 45 mins turn it over and it fires up like nothing was ever the problem and normally drive several hundred miles trouble free again until yes you've guessed it next day or week you drive a mile and life repeats itself. Any help please !!! before I buy a box of matches
Old Oct 29, 2006 | 02:32 PM
NZ_Benz's Avatar
1993 300SEL/S320
You think it could be a charging problem with the battery, the alternator or something?
Old Oct 29, 2006 | 04:16 PM
ajbristol's Avatar
300SEL (S320)
Can't see it being the battery somehow as when it cuts out I can try to start it and it will turn over and over and over for anything upto 10 mins but does not start... does not even fire ! so battery good just engine dead
Old Oct 30, 2006 | 10:07 AM
Rod Spohn's Avatar
2011 E350 Bluetec, 1996 S320 & 2006 E320 CDI Sold to my son & 2017 GMC 2500 Diesel Pick up
Just an Idea, what about the fuel regulator. Sounds like you are maybe not getting fuel sometimes.
Old Oct 31, 2006 | 08:33 AM
pcmaher's Avatar
1995 S600 Sedan
Have you pulled codes?
Old Oct 31, 2006 | 08:44 AM
shadowgriffen's Avatar
is a German Tank
Over Voltage Protection? Dont know about your cars (140s) but w124s are prone to die out and cause all sorts of weird starting issues due to OVP relay.
Lays behind the battery (behind black plastic shield, next to ECU 10A fuse)
