S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
probs with my car
Old Dec 18, 2006 | 03:15 AM
TINT's Avatar
probs with my car
i got a 92 400se
recently, i took offf the driver side rear tire to get a nail taken out and patched. came back put back on again. now, with the weather being colder when driving around its squeeking! loud. like its a real old car, it only squeaks in the area where i took off the tire! no where else.
second problem. the driver side door is not "sucking" in anymore. is this expensive to fix? i think the passenger side is wanting to do so as well Shocked
third. few months back i had a new belt put on my benz techs. i've had to take it two times cause it would go lose and/or squeak. now, its squeaking again. does it take time to adjust?
im thinking of selling this car. as they are prone for problems
Old Dec 19, 2006 | 10:55 AM
6_0_0's Avatar
Had the same - the drivers door not "sucking".
The vacuum pump worked well, as the rest of three doors worked OK 100% of times.
The reason was a micro switch that activates the "sucking". This switch is a part of the lock (and the lock itself is quite expensive), but they were able to easily do something to this switch only and now it works fine.
Old Dec 19, 2006 | 11:59 AM
Peter Guenther's Avatar
92 500sel/01 320e wag
Microswitch maybe, but far fetched
http://v12uberalles.com/
