S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
ASR Light and reduced engine power?
Old Jan 22, 2007 | 02:27 PM
2004jetta's Avatar
Hey guys, first time poster here. So my dad has a '95 s420 with 119k miles on it. Posting up because in colder weather the car sometimes turns teh ASR light on, when this happens the engins power is greatly reduced. I have found that turning the car off and on again tends to solve this problem. Now I'm on other forums so I know to search before posting but noone else seems to have this problem. Any idea's on what might be causing this?
Also the little plastic protective cover in the shift gate has broken, doesn anyone know where I can find this and about how much it would set me back?
Old Jan 23, 2007 | 05:38 PM
gartracescort's Avatar
S500L, 1995
Same here just after new engine, loom and (rebuilt) throttlebody install and today.
Old Jan 24, 2007 | 09:59 PM
mbcrazy's Avatar
1998 s320 is mine.Wife drives 2002 c32
i had same problem in very cold wheather.your power is reduced because when asr comes on it automatically reduced engine power,so its normal.my problem was gone next day when it got warmer outside
Old Jan 25, 2007 | 07:17 AM
S500L, 1995
From the way it behaves, it might just be condensation on the rheostat tracks causing a bad signal and panic in the ECU.
Old Jan 25, 2007 | 12:51 PM
2004jetta's Avatar
So you're saying I have a moisture getting to the rheastat? How can I find it, maybe I can restore the seal somehow???
