S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
shimy at 60 mph and hard ride in the rear
Old Mar 26, 2007 | 10:58 PM
Gman91932's Avatar
1995 S320 and 1995 S500
My s500 has a shimmy at 60 MPH and it rides HARD in the rear. (as if struts or shocks are bad) any ideas and ho about cost?
Also the other S320 AC does not work, is it any inexpensive way to fix AC
Gman
Old Mar 27, 2007 | 09:35 AM
Peter Guenther's Avatar
92 500sel/01 320e wag
The signs of bad accumulators are a songey ride , and the a hard ride as all the nitrogen bleeds off, the reservoir should be low. If the struts leak they are bad, if they dont they are probably still good.
The AC on 140s is complex, there are many sensors and controls. If there is a leak the compressor wont come on, I hope you are not a victim of the 140 evaporator failure, it is a $5000 fix at MB, the dash comes out of the car, and most of the time they replace hoses filters and seals. Just dont have anyone do the repair, my local dealer has a couple of guys who have done it many times!
Old Mar 27, 2007 | 11:24 AM
Gman91932's Avatar
AC compressor
IF the ac compressor comes on, then what about a leak. For instance when I last filled the AC it lasted about a month.
Gman
Old Mar 29, 2007 | 01:07 AM
brett san diego's Avatar
1997 S600 Sedan
You have a leak somewhere in the system. There are some stop leak products that you can add to the AC system. But, as is often the case, there is the cheap way to fix a problem, and then there is the right way.
Brett
Old Mar 29, 2007 | 11:51 AM
Gman91932's Avatar
Thanks Brett
Nice to hear from a trusted member. I now work in Solana Beach. My mechanic doesnt do AC. Can you recommend someone reliable to diagnose and possibly fix this issue. Why have a car like this if you cant enjoy it?
All the best
Gman
Old Mar 29, 2007 | 05:02 PM
Gman91932's Avatar
Evaporator failure
I spoke to a mechanic who informed me that it is probably the evacuator failure! But I do not have thousands to fix it. Any suggestions?'
Gman
Old Mar 29, 2007 | 05:45 PM
The sealants also can gunk up the system, a good shop can fill the system and use a sniffer or dye, the rest is unpedictable
