1996 s 500just bought it,couple questions.
the a/c has a funky smell,i had it charged a week ago now its not as cold ?any one have any sugestions. 2,when i drove on the hwy. if there was a dip the rear part of the car sounded like the drive shaft or something was grinding against the chasis? again any help would be welcome.
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
Steve, there is a drain tub for condensation that have been know to clog on other cars I've owned that caused a bad smell. Never has that with my Benz however but may be worth checking. I would be more concerned about the grinding noise. I f you are a DIY guy check the flex disk that connects the ends of you drive shaft. They get brittle and start braking away. Also may be the wheel bearings. ( not a DIY thing) Find it, fix it before it costs a lot. Sorry I can’t tell you.
Brett
1999 S320 LWB
My S320 has a worn front flex disc...I found that out when I took it into the dealer for it's first LOF on Tuesday. They said that was the cause of that squeak sound that I hear when I put it into reverse. I think they quoted me somewhere between $350 and $450 to have it replaced.
