S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
98 S420 19 Wheel Fitment
Old Oct 7, 2007 | 12:42 PM
CaliE320's Avatar
88 260 E
Hey Guys,
So I ended up purchasing a 98 S420 instead of the coupe. Question now is wheel and tire application. Alot of you guys are running 44 eta offset front and rear. Can I run instead 35 eta front and back? As well should I run 245 45 /19 up front and 245 /40 rear to fill up the wheel gap without rubbing?
19 x 8.5 Front eta 35mm
19 x 9 Rear eta 35mm
Thanks,
Cali
Old Oct 7, 2007 | 03:49 PM
Mastodont's Avatar
1992 W140 400 SE
That should go fine. I have 9"x20" with 255.35.20 all round Et 35 and that is no problem.
Old Oct 22, 2007 | 01:17 AM
CaliE320's Avatar
88 260 E
Thanks I ended up going with 20's.
OG Brabus IV's on Nitto 245/35
I'm surprised the ride was not as bad as everybody was saying. The ultimate test was Sat night had the car loaded with 2 gurls and two big homies and no rubbing what so ever. The Nitto 35's have a taller sidewall then Pirelli, Khumos or Falkens, weird cuzz I thought they should all be the same if they're 245/35s no matter what brand they are they should all have the same dimensions. Did a side by side comparison and the Nittos were definitely taller.
Has about a 1 1/2" wheel gap, not too bad but I would like to lower it., anybody have rubbing issues on their lowered W140's on 20's? Thanks for everybody's input on this project, everything is coming together nicely. I've had it for two weeks and this is what I've done so far (White 98 S420)
Full service
flushed all fluids, tranny service, plugs etc.
clear corners w/chrome bulbs
smoked led taillights
chrome front and rear ac vents
chrome shift surround
chrome shift plate
chrome door handle covers
S600 grill
light tint
Burlwood/chrome shifter
20 chrome Brabus Monoblock IV's original not replicas
I usually don't like chrome but chrome on a white W140 actually looks good.
Coming soon
OEM Xenon conversion
Brabus front end
Brabus exhaust (if I can locate one)
Brabus or MB illuminated door sills
Brabus puddle lights
~Cali
Old Oct 23, 2007 | 04:54 AM
Mastodont's Avatar
1992 W140 400 SE
I have 255/35x20 Yokohama and the car is lowerd 40mm. No problems with the rubber anywhere.
Old Oct 23, 2007 | 11:59 PM
CaliE320's Avatar
88 260 E
Very nice, what kind of lowering springs did you go with?
~Cali
Old Oct 24, 2007 | 12:33 PM
Mastodont's Avatar
1992 W140 400 SE
The springs are Schatz http://www.schaetz-tuning.de/index.html.
