S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
1999 S320 Instrument Light Out
Old Nov 14, 2007 | 04:48 PM
viperbyte's Avatar
1999 S320
Question 1999 S320 Instrument Light Out
One of the lights that illuminate the instrument panel in my 1999 S320 has burned out. It is the one on the left side behind the tach and clock. Are these bulbs or LED's? How hard is it to replace, and just how would one go about doing that? Thanks in advance!!!
David Wilson
Old Nov 15, 2007 | 09:00 AM
MBProS320's Avatar
1984 300 D // 1995 Lexus ES300 // 1998 S320 // 2000 S500 // 2006 Lexus LS430 // 2007 Ford Expedition
If I can recall correctly, once you take the instrument cluster out of the dash, and disconnect the wires, you can easily access the bulbs from the back. Just twist the bulb out, get the new bulb in, and put it right back in.
Last time I had this issue, thats what my MB guy did for me, and it took no more than three minutes. You just might have to run to your local stealership and buy the tool to get the instrument cluster out of the dash. Should be fairly cheap.
Old Nov 15, 2007 | 04:15 PM
NZ_Benz's Avatar
1993 300SEL/S320
http://v12uberalles.com/instrument_cluster_removal.htm
That tells you how to remove the cluster.
Old Nov 21, 2007 | 03:29 PM
w140s320's Avatar
merc s320 w140
try this
funny i have had same problem with my dash light bulbs out but all i do is give the top of the dash a smack and presto the bulb relights itself. but if yours still refuses to come on then i guess it has burnt out. all the best.
Old Nov 21, 2007 | 05:01 PM
NZ_Benz's Avatar
1993 300SEL/S320
Sounds like it might be worth cleaning the contacts of your bulbs.
