S-class (1994) Headlight Upgrade
I wanted to upgrade the 1994 OEM headlights from my s-class to the 1995-99 type. I purchased a pair of the newer style, but I am not sure how to install it? Does anyone know how or where I can find out? Thanks.
1989 300TE - 1994 E280
I have a 1994 E280 with clear corners. If im correct it would be the same installation procedure as the W124 model. It takes about 10 mins and if u have the owners manual is explained in there.
Chris
Chris
in gerneral the pre poster is quite right. But do know how to replace it for the W124????
so: first take out the corners, by unpluging the the wires, and snap the plastic part from the inside of the hood. Then remove the washer/wiper assembly, disconnect the vaccum hoses from the housing, remove the wiring and then unscrew the headlights. After installing the new once have them readjusted at garage.
