S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
ABS and ETS warning light on
Old Apr 27, 2008 | 10:38 PM
Gman91932's Avatar
1995 S320 and 1995 S500
Help if you can. Both the ABS and the ETS light came on, on Friday. They are continuously on while driving. What does it mean? Manual say consult your Dealer.
Best
Gman
Old Apr 28, 2008 | 04:26 AM
ohlord's Avatar
Do
your brake lights work?Bad brake light switch is often the cause of those warnings.Also if your battery falls below a certain voltage it can trigger those warnings
ohlord
Old Apr 28, 2008 | 09:15 PM
Gman91932's Avatar
How does one check the brake light switch. Where is it. I am not but can do somethings or take it to my mechanic.
Best
Gman
Old Apr 29, 2008 | 04:44 PM
Gman91932's Avatar
I had the breake light switch changed. IT still has no lights and the dashboard still has the ABS and ETS lights on. Any suggestions
Gman
Old May 1, 2008 | 03:20 PM
Gman91932's Avatar
Problem solved..THIRD brake light!
The third brake light that was sold to me by the Mecerdes dealership was the incorrect one. This is in the area above the trunk behind the rear seats. The contacts were different. Went back.. got the right light and voila! all fixed.
go figure!
Gman
