S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
S500coupe or S600coupe???
Old Dec 26, 2002 | 07:43 AM
bazzis's Avatar
500sl
Question S500coupe or S600coupe???
I'm about to buy either a S500 coupe or a S600 coupe,would like some advice on the differences of owning and running these cars, many thanks.
Old Dec 26, 2002 | 09:20 AM
Mr. Xristo's Avatar
1995 Jaguar XJS Convertible
If you can afford it, I would go with the new S600. I would choose the Designo Graphite, along with the sports package!!
The new S600 is a much more luxurious vehicle over the standard S500, and is a bit more powerful (more torque) than the S55
S600
- 493 hp @ 5,000 rpm
- 590 lb-ft @ 1,800 - 3,500 rpm
Whichever one you decide upon please, please, please purchase the sports package!! The stock wheels are dreck.
Old Dec 26, 2002 | 06:36 PM
Dominic's Avatar
Exclamation
If I'm not mistakened I believe bazzis is talking about a W140 Coupe.? In this case it I would without a doubt choose the S600 Coupe. Considering they're more rare the the S500 Coupe and seeing that the S600 is usually well taken care of because of that I still say the S600 is a better choice. Even if they is a 1 or 2 year difference it's more exclusive, powerful, and rare. I'll also bet that even with a 1 or 2 year difference the S600 Coupe will almost always have less mileage. The S600 will win every time in my comparison. Just my 2 cents!
DOMINIC
Old Dec 27, 2002 | 04:46 AM
bazzis's Avatar
500sl
S600 v S500 coupes
Sorry, I did mean the W140 cars, thanks for your help......
Old Dec 28, 2002 | 12:54 AM
zindallas's Avatar
1998 cl 600
bazzis
Depends on what you are looking for.
The price difference between the 2 is pretty narrow now - especially considering the 600 was $40K more new!
If you want max luxury and performance with a little pricier maintenance then I'd definitely go with the 600.
The 500's are nice too and the 5 liter V8 is a MB workhorse with a good history.
You can find 500's pretty easily, 600's are rarer. I'd suggest you look at as late a model as you can afford as the S's are packed full of goodies that take MB several years to de-bug.
I found a 98 CL 600 with only 34K on the odo, and while I've only had it 2 months, I love it!
You can't go wrong either way with this incredible car.
Z
Old Dec 28, 2002 | 10:28 AM
Mercedescl600's Avatar
I also have a 98 cl600. And i have a 97 S500 sedan. so I drive both engines. If its the engine your asking about i can tell you the S600 in the coupe is far more powerful and is alot smoother. If your going to get a 600 you should get at least a 96 or is it 97, whenever they changed to the 5 speed. They had engine oil leaks in the 4 speed version on almost all 600s The part that sucks is its a $3000 fix. I was gonna buy a 94 600 sedan back in the day, but it had this problem also. So if you want to spend in the 30 to 40 grand range then get a 97-99 600coupe, If you dont want to spend as much get a 500. I would not recommend an older s600, Unless you have unlimited funds for maintenance. hope i helped.
Sam
