A/C recharge
Thanks for any responses
If it blowing ambient temp air or the compressor is not spinning at all,have it looked at by an indie shop.If it is blowing cool air,toss in a can of r134a (make sure it is not the crap with the stop leak junk in it)and see if that helps.It can only go in one fitting and that is usually located along the tube and has a black cap.
follow directions on the can.
If you have lost all of the r134a ,you need to locate the leak and get it repaired.
