How to remove transmission shift gate?
Thanks!
www.benzworld.org w210 diy section.
Did you spill something down the console?Have you checked that the o ring and electrical connector to the trans on the passenger side of the trans has not leaked and needs to be replaced with the upgraded unit.
also time to change the fluid and filter on the 5speed mb spec 722.6 fluid only.
I have the special dipstick if you do the diy.
I can't get the block out! I don't see anything in the W210 section regarding the shift gate.
The car has a 20k old transmission (installed new @ 100k), fluid should be good to go.
http://www.benzworld.org/forums/w210...e-replace.html
also
http://www.benzworld.org/forums/w210...t-shift-d.html
in case the po dropped something in there or corrosion on the disengagement pin.Also check that you shifter bushing is not broken or worn out.
