S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Seafoam
Old Mar 18, 2009 | 09:07 PM
aallii1991's Avatar
1993 400 sel
Seafoam
Hello everyone. just a quick question i am going to seafoam my engine tomorrow, just wondering if anyone has tried it and have any tips or suggestions. also have you seen a difference at all? how exactly do i do it?
thanks for any help
Old Mar 19, 2009 | 05:32 AM
ohlord's Avatar
You
don't need to do it.Just run your tank down to near empty add a can of seafoam to the tank fill it half way and drive it as usual till it is almost empty again,then fill as usual with premium.
Do it once yearly.
The other process injects the seafoam into a vacuum line going to the intake manifold and you really have no need for that and all it entails(smoke,risk of stalling with to much injected ,etc.)
Old Mar 23, 2009 | 12:20 PM
Rod Spohn's Avatar
2011 E350 Bluetec, 1996 S320 & 2006 E320 CDI Sold to my son & 2017 GMC 2500 Diesel Pick up
DITTO
I have done this as stated above. It made a noticeable difference the first time and now I do it a couple times a year just as preventative maintenance thing. I have always wanted to try the vacuum line way but like you don’t want to do it without a better idea of where and how to do it. Good luck.
Old Mar 23, 2009 | 08:13 PM
aallii1991's Avatar
1993 400 sel
yeah i am kinda afraid too kill my engine haha
Old Mar 23, 2009 | 11:52 PM
TMAllison's Avatar
09' E320
Which YOU are capable of doing if you introduce an unmetered fuel source into the intake/fuel supply. (if you feel the need to test this just spray ether into it while its running and see how long rpm's rise after you decide to let go of the button)
Put it in the tank and call it good, or see the mech if its not.
Old Mar 24, 2009 | 06:25 PM
MTI's Avatar
MTI
'85 190E 2.3-16 '99 C280 '11 GLK350
I've done the Seafoam, and BG44K, vacuum intake manifold hot soak a dozen times . . . haven't killed an engine yet . . . haven't seen any leaking fluids or oil drips . . . but have gotten odd looks from neighbors over all the smoke.
Adding it to cheaper unleaded fuel is a good idea, much like adding the STP or Chevron detergents, but not nearly as effective as the hot soak.
Old Mar 26, 2009 | 01:33 PM
Rod Spohn's Avatar
OK - any guidance / DIY info to share with us? How and where to tie in etc.?
Old Mar 26, 2009 | 01:47 PM
ohlord's Avatar
You
can feed it in via the big vac line from the brake master.But all it really does is smoke and sputter,mostly show.
Just add it to your tank,it will clean the fuel system.
But if you insist the vac line and slowly adding to prevent hydro lock will smoke the neighborhood up real nice.
Old Mar 26, 2009 | 07:13 PM
aallii1991's Avatar
1993 400 sel
thanks everyone! i just put it in the tank..... hopefully works out well.
Old Mar 27, 2009 | 10:46 AM
Tommy_s4's Avatar
ML320, Looking for my S4
Dont do it, I've heard horror stories of it being done and older cars loosing compression due to the carbon deposits actually filling cracks in the cylinder walls and seals in the valves. Its a great product in theory.... however in practice it can become a night mare. If needed add it in the gas tank with a bottle of lucas F/I cleaner.
Old Apr 25, 2009 | 10:44 PM
lomita's Avatar
C63AMG
Don't worry. Seafoam works great on any engine. We're hands on with using this product on our vehicles. Great in the intake manifold, can be used in the oil prior to oil changes, and can be used as an injector cleaner, just put it in the gas tank. Luv the smoke cloud, and so do all my neighbors. Better when windy.......nuff said.
Old Apr 29, 2009 | 08:09 PM
Goatman's Avatar
1987 SDL; 2001 Chevy 2500HD CC, 8.1L, Allison special order; 1970 GTO LS2, 4L60E, under construction
Have run Seafoam in ALL of my vehicles for the last 5 years or so. Directly into the intake, wait 15 minutes, fog the neighborhood for mosquitoes..
Simple as can be, NO DAMAGE EVER. Even in my higher mileage vehicles. Running it in the tank runs the risk of disolving crud on the tank walls and sending it through the filter and injectors. **** poor advice from TMA, again...
