S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
95-S500 occasional stalling when stopped at intersection...
Old Jul 11, 2009 | 12:22 AM
DragOn67's Avatar
S500
Hi,
I have this problem just recently... I bought it in 05 when it has 95K miles. it now has 130K. It runs well otherwise, on highway
Is there anything that I could do to fix this? Would replaceing the fuel relay fix this problem? Or anything else? May be a full tune-up with new wire set, plugs, filters, etc???
Thanks for your help.
DG67
Old Jul 11, 2009 | 01:48 AM
TMAllison's Avatar
09' E320
Have you used the code reader under the hood to see what codes might be stored? Yours is an OBD1 system that give codes as a series of blinks.
Old Jul 11, 2009 | 11:24 AM
DragOn67's Avatar
S500
Hi ,
Thank you, TMallison, for your reply. I'm quite new to this forum and the car. Could you please elaborate a little more and tell me what the code reader is? how can I get them? how does it help me fix my problem?
Thanks.
DG67
Old Jul 24, 2009 | 08:10 PM
dickster601's Avatar
s430 2002 and s500 1996 mercedes benz
my 1996 s500 is doin the same thing. it stalls upon xcelleration and then takes off. ruff idle at times and it use to put off this horrible gas smell.. what do i need to do??
