S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Weird Problem,,,
Old Jul 12, 2009 | 01:42 AM
assman300's Avatar
1999 s500
Weird Problem,,,
Hello all,
A weird thing happened tonight with my 99 S500,,,
I was driving around, and all of a sudden the ASR light, and the check engine light came on, and at the same time the temp guage went all the way to down to 0,,(the guage went dead) i pulled over and shut it off, and then restarted and everything was fine,, back to normal,,
then i was driving about 2 hours later,, it started to missfire pretty bad,, and the check engine light came on, i once again tried shutting it off,, but when i started the problem presisted...
im gonna pull some codes on it,,, but has anyone else ever had anything like this?
thanks..
Mike
Old Jul 13, 2009 | 02:45 PM
javaco888's Avatar
2005 W211 E320; 1995 W140 S500
i had a problem with my ASR light coming also and would put the car into limp/safe mode... but it didn't cause a misfire...
Not trying to knock mbworld, but there's not many w140 people consistently on here.... try posting your question on benzworld.org... a good amount of w140 people on there...
just my .02...
Old Sep 10, 2010 | 10:05 AM
preston's Avatar
2002 s500
wierd prob
2002 s500, riding along "ESP" message came up, panel lights came on, engine shut down. would not restart. had towed, got to mechanic and engine started w/ check engine light on.
Old Sep 22, 2010 | 04:18 PM
CaliE320's Avatar
88 260 E
Same thing happened to me not to long ago, ended up being a bad coil. Replaced cylinder #3 coil.
