S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Voltage problem? Battery light ON with 15.6VDC
Old Sep 24, 2010 | 01:09 PM
Voytech's Avatar
Mercedes
I got a 1995 S-420 that the battery light is on on the dash, but if you put a voltage meter read 15.6 VDC. Any idea, HELP
Thanks Voytech
Old Sep 25, 2010 | 04:43 PM
oldsinner111's Avatar
s320
On my w126 the alternator has a removable voltage regulator.I don't know about your car.My regulator was bad and I was getting 18 volts.I replaced it and got another year out of the alternator before rebuilding it,a few weeks ago.
Over charging can weaken other things like radio,lights ect... It can also mean that battery has shorted cell.
Old Sep 25, 2010 | 06:57 PM
Peter Guenther's Avatar
92 500sel/01 320e wag
I read somewhere in a technical manual it looks like the system checks for over and under voltage.
Having said that, I had my instrument cluster rebuilt for the very common flashing issue on the early 140s. The cluster came back and the battery light came on after the inital startup and would flicker in a random fashion for a while. I assumed the alternator had failed and MB and my indi verified charging. The end result was that after replacing the alternator, the random flashing continued, and one day it was gone, and has not returned.
