S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Rotora Big Brake kit on CLEARANCE!
Old Jul 17, 2009 | 08:30 PM
VividRacing's Avatar
Former Vendor of MBWorld
G63, C190 AMG GTC, W209 CLK63 BS, W208 CLK430
Hey guys,
There's a set of ROTORA BBK available under clearance for your S-Class W140
Features:
-Rotora billet aluminum alloy piston racing calipers with sequentially sized piston bore sizes engineered to each specific vehicle.
-Rotora billet aluminum hat with �floating� disc assembly to reduce heat related stress and unsprung weight.
-Rotora 2 piece vented heat treated directional vane disc system to improve airflow/cooling under severe braking. Slotted or drilled & slotted oversize discs (355x32mm) to ensure equal heat dissipation and increase thermal capacity while relieving the disc and brake pad surface free of excess debris.
-Rotora ceramic formulated pads designed for extreme street and track application with high co-efficient of friction and high temperature fade resistance.
-Rotora DOT compliant stainless steel braided brake lines to improve stiffer pedal feel and prevent brake hose expansion.
-Rotora carbon steel (SC45) mounting brackets (depending on application) and hardware.
Clearance Kits available in:
Front- 6 piston 14" $2,695.00 $1,886.50
Rear- 4 piston 14" $2,195.00 $1,536.50
**Sale price marked in RED
-2 sets left in RED & METALLIC BLUE Calipers with DRILLED/SLOTTED Rotors
Contact ME if you have any questions or to place an order - 480 966 3040 ext 228
Old Jul 20, 2009 | 03:26 PM
hellah fresh's Avatar
Was 89' 300E, Now 93' 500SEL
i dont see the big brake kit for the same price.. am i looking at the wrong place?
Old Jul 23, 2009 | 01:21 PM
Pm's sent and replied!!!
