S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
96 S600 wont upshift
Old Sep 2, 2009 | 01:17 PM
dcsurgs003's Avatar
SL500
96 S600 wont upshift, already replaced transmission plate same thing any other ideas.
Old Sep 2, 2009 | 03:03 PM
TMAllison's Avatar
09' E320
I believe you've got the electronic 722.6, assuming so, you'll have to clear the trans codes before it will work again even if what you've done fixed it. OBDII scanners cant do that (they only see and clear the generic codes such as P715 or P720, etc.); disconnecting the battery won't clear them either. Needs SDS or other high end scanner to read that module.
Old Sep 2, 2009 | 06:44 PM
rizzy's Avatar
none
It may or may not be a 722.6 transmission. It could be a 722.5 with a throttle valve cable going from the throttle linkage to the transmission. It could be broken or in need of adjustment. There should also be a vacuum line going to the transmission modulator valve as well. They are known to get swollen and tear.
