S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Smell of burning plastic
Old Jan 10, 2010 | 10:34 AM
garvinder's Avatar
1998 S320W
I have a 98 S320 and have been smelling burning plastic from the front while driving. I turned off the blower to see if that had any impact and it still stunk. What could possibly be melting? Has anyone had a similar experience?
Old Mar 5, 2015 | 09:28 AM
usermike9's Avatar
97 S420
Burning Smell
Sounds like your main engine wire harness is experiencing the breakdown that they all do. Mercedes must have found the cheapest garbage they could to make these wire harnesses. They rot and fall apart causing a whole array of issues. Here are two links about the harness decay. First is a thread about 1000's of complaints to the NTSB . The second is a service that will rebuild the harness far less expensive than a new harness.
https://sites.google.com/site/infoag...harness-defect
http://www.restoreyourmercedes.com/m...20rebuild.html
Old Mar 5, 2015 | 10:07 AM
oldsinner111's Avatar
s320
car after 96 do not suffer this problem.The v8s have a place on the block that can rub the block.the smell could be a leak in the valve cover.
