S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
s500 Drive Belt Idler Pulley
Old Feb 27, 2010 | 05:52 PM
captain1976's Avatar
S 500
I have a 2000 S500 and it was making some noise. I found it was coming from a split pulley. I assume its called a belt idler pulley but am not sure. I'm not sure what it drives but it is grooved and sits on the highest point a bit to the passenger side of center. It is currently running on only a couple of grooves as it split in the middle. Also seems to be running OK but I don't trust it.
Its made of some kind of plastic material.
Can anyone tell me if the pulley comes off separately or must I buy the assembly its attached to. Also any recommendations on where to get it would be appreciated.
Old Feb 28, 2010 | 12:34 AM
napaAl's Avatar
1996 S320 SWB, 1998 S600
post a picture if you can.
Old Feb 28, 2010 | 07:28 AM
benica's Avatar
1998 and 2002 SL 500, 2014 E550 Convertible
Been their ...done that....e-bay has them...
I will give you some advice.....do NOT try and save money by buying only the pully or the tensioner.....99% of the time, if you replace only the pulley and reinstall it...the tensioner is now bad and you have to now buy the tensioner!
The tensioner takes a beating...the inside has a rubber bushing that is stretching over time...it is constantly moving....do yourself a favor a get the complete setup....pully and tensioner....between $150.00...~$300.00 on e-bay....do not buy used!
I realize that just because folks own a mercedes...it does not meant they can afford it!
The belt tensioner is important...don't buy used or el cheapo.....
Old Feb 28, 2010 | 11:53 AM
S 500
OK, I appreciate the info but I'm still not sure if it is the tension pulley or not. Here is a picture and its the small pulley right on top of the picture.
Old Feb 28, 2010 | 11:21 PM
napaAl's Avatar
I don't have an S500, so I can't say for sure, but that pulley appears to be a mechanism, like an air pump possibly. An idler arm takes the slack out of the belt, and looks more like an arm.
