S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
92 500...keeps blowing....
Old Apr 25, 2010 | 09:07 PM
benica's Avatar
1998 and 2002 SL 500, 2014 E550 Convertible
the number 11 fuse in the trunk keeps blowing..."window lift, luggage compartment light, centr. locking syst., (ceiling reading light rear)
No one has done any work on this car recently for this problem to just pop up!.
Any suggestions or ideas? How would one trace the particular item that might be causing the problem? I figured to just pull the fuses until I found one that was not causing number 11 to blow....but, the window lift, etc. are all tied into one circuit...so...
Old Apr 27, 2010 | 01:19 AM
napaAl's Avatar
1996 S320 SWB, 1998 S600
You could eliminate one load at a time, including wires. It helps to have a schematic on hand. Good luck.
