S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Trunk lid doesn't suck in
Old May 13, 2010 | 04:42 PM
qha000's Avatar
Hey all,
I had heard about problems with the driver's door suction problems but yesterday my trunk lid out of the blue stopped sucking in even though the handle does pop in and out, any ideas? Do I have a leak in the system?
thanks,
Old May 19, 2010 | 03:53 AM
otown600's Avatar
600sel
I have the same problem. Someone help!!!
Old May 23, 2010 | 01:24 AM
mrevilandy's Avatar
1995 s500
Hi, been around the forum as a guest longer then a member and this is my first post. I have a 95 S500 and I've experience the same thing. What worked for me was pulling out one of the fuses in the trunk for 5 secs and everything worked fine. Happen a few times and this always fixed it. Its the middle top fuse.
Old May 23, 2010 | 12:01 PM
hcetzneb's Avatar
2004 Ran SRT-10,2007 S550,2016 E400c
Pull the fuse to the closing assit pump ( might be 2 fuse) This will reset the pump . Than re try the trunk a bunch of times and listen by the handle area. ( IF you know how latch the trunk with the lid open and listen on the inside) .. You probalby have a leak in the diaphram of the actuator.
If the CL pump detects opperation of i think longer than 90sec ( a leak) it will shut that circuit of the pump off as not to burn out the pump
Good luck
