S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
w140 key remote total closure
Old Jun 10, 2010 | 02:28 PM
w140s320's Avatar
merc s320 w140
can the car be programed to do the reverse ie drop all windows and open the sunroof when you press and hold the unlock button?
Old Jun 11, 2010 | 08:13 PM
Vasir's Avatar
99' SL500, 16' i3, 14' Passat TDI SEL
ive been told yes, but i think its a rumor. ive had my s320 since 1996 and i have never seen it happen. when i asked my service advisor at the stealership he said 'i think so, but i havent seen your body style car in so long, i dont remember anymore'.
Old Jun 13, 2010 | 10:08 AM
wbrian63's Avatar
02 S55
The ability to open the windows is only designed as a "safety measure" related to the ability to close them.
From the owner's manual regarding closing the windows with the remote:
In case the closing procedure causes potential danger, the closing procedure can be immediately reversed by releasing and pressing the remote control button again until the green indicator lamps at the receivers blink. The sliding/pop-up roof and windows will open again. The sliding/pop-up roof will only open if it was not fully closed.
From the owner's manual regarding closing the windows with the key:
In case the closing procedure causes potential danger, the closing procedure can be immediately reversed by turning the key to the unlocking position within 10 seconds. The sliding/pop-up roof and windows will open again. The sliding/pop-up roof will only open if it was not fully closed.
I think the 10 second rule also applies to the remote-triggered process.
What I seem to remember is it only applies to the windows that were being closed during the closing procedure.
Old Jun 14, 2010 | 12:13 PM
w140s320's Avatar
merc s320 w140
thank you, your absolutely right, only the the windows and roof closed by the remote will re open in certain time limit., but i would like no time limit for reopenning. any ideas would be fantastic.
