S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
1996 Mercedes S600 ABS, ESP, and ADS trouble lights all on solid
Old Jul 22, 2010 | 07:00 PM
dingledork's Avatar
S600
I'm new to this forum, new to MB's, and would appreciate any help I can get. Here's my problem:
1996 Mercedes S600. Battery had been dead for quite a while, replaced w/new battery. ABS, ESP, and ADS trouble lights all on solid. Steering turned from full lock left to right to reset ADS, will not reset. OBDII scan shows no trouble codes. Once in a while vehicle will start with no trouble lights. Once, vehicle oscillated brake, triangular ESP lamp flashing, seemed to be left rear. Problem quit after cycling ignition twice. ABS, ESP, and ADS trouble lights stiil on. Vehicle otherwise operates fine. Suspect a wheel speed sensor, but why no trouble codes?
Old Sep 9, 2022 | 05:38 PM
Petrov83's Avatar
w210 w140
Since 2010 no one have replayed for these issues
unfortunately I am after these problems as well
Old Sep 18, 2022 | 04:38 PM
JohnLane's Avatar
222 S-65
Get Mercedes or a properly equipped independent shop to perform a quick test with those warning lights on.
ABS sensors can be intermittent... rodents find wiring to be particularly flavorful.... it happens.
Old Mar 28, 2023 | 08:00 AM
Goz007's Avatar
W114 280se
Start with scanning for fault codes.
